Don't Connect CATV to OTA Antenna System
An active cable TV signal includes frequencies used for aircraft communications and navigation. If you connect the cable TV system to your antenna you will very likely cause harmful interference to aircraft, fire and police frequencies.
As JC has already said, "DON'T DO IT."
If the cable TV folks have been fired, you can re-use the abandoned cables and splitters in the building.
A thread re. Grounding
