Tv Antennas and Reception
Yes you can use the cable wiring for the antenna wiring. However DO NOT connect the Antenna and active cable Tv or active cable internet service or cable delivered phone service on to the same coax at the same. I will say it again , DO NOT and I mean DO NOT combine the Antenna and active cable Tv or active cable internet service or cable delivered phone service on to the same coax at the same time. If the cable coax line is active with any type or kind of cable delivered services , DO NOT connect the Tv antenna to it.
