If you think the TVFool report looks terrible, then you haven't taken the time to read the Signal Analysis FAQ which has a link at the top of your report. Take a momenet to read that, and you'll discover that you have one of the best scenarios possible: all stations of interest grouped in the same direction, all major and minor broadcast networks available, only UHF channels used for broadcasting, and plenty of signal strength available.
You only need a modestly sized UHF antenna AND NO AMPLIFIER. Antennas such as the Antennas Direct Clearstream 2, ChannelMaster 4220, or Winegard HD-1080 aimed at about 300* azimuth will suffice, even with the cable run inside. You could probably drive 4 TV's with simple splitters, too.
