Old 13-Jun-2011, 9:37 PM   #1
jtnichol
CS4 + CS5 + Winegard AP-8275
Ok i'm a noob. I've been poking around for answers too so I understand this a little more anyhow.
I plan on mounting these antennas 4' apart on a rooftop mast. I plan on using a supplied Combiner with the Clearstream 5 then after both leads go to the combiner where I will then run the combined coax stream to the house. Inside the house is where I plan to add the amplifier.
Here's my map according to TVFool with a 30' elevation approximate from the address ground level.
Looks terrible but I figure its worth a shot with these antennas.
Any other suggestions? More height?
jtnichol is offline   Reply With Quote
