Old 12-Jun-2011, 11:16 PM   #7
There is more to reliable reception than signal strength, which is important. Signal quality includes several other factors. The bottom line is, an amplifier has it's place -- after an antenna that is receiving signal of sufficient quality.
http://forum.tvfool.com/showthread.php?t=1514
I won't go so far as to tell you, "Don't use an amplified antenna." I simply want to be sure you understand what an amplifier can do, both the positive and the negative.
