Old 12-Jun-2011, 10:04 PM   #5
John Candle
Tv Antennas and Reception
Here is how to point indoor and out door Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html . Point the antenna at about 130 degree magnetic compass. Exclusive use of the balcony means that the balcony is connected only to your apt.. That means you can put a antenna on the balcony. The DB4 antenna can be mounted on a tripod mount , the tripod mount will stand on the floor of the balcony and can be made stable with a weight. A flat antenna cable can be instaled at a window or door , http://www.parts-express.com/pe/show...number=180-206 . Here are some places to buy Tv antennas and etc. , http://www.solidsignal.com , http://www.3starinc.com , http://www.starkelectronic.com , http://www.amazon.com
