Tv Antennas and Reception
A "test cable" is simply a loooong length of RG-6 coax connected to matching transformer at the antenna and then directly to one Tv. The looooong length of cable can be run through a open door across floors to the Tv. Is the antenna on the outside of the building on the roof or is the antenna in the attic?? If the antenna is in the attic of the building structure , is the place where the antenna is at have a metal roof , is the building wrapped with any kind of metal. Is there any foil backed insulation in the attic?? What direction is the antenna pointed??
