Tv Antennas and Reception
By giving an example of a 8 way splitter GUM is making a point that the Tv transmissions are strong. He is not saying install a 8 way splitter. I say that if 1 Tv is connected then use No splitters at all. I say that if 2 Tv's are connected then use only one 2 way splitter with the 2 outputs from the 2 way splitter going directly to the 2 Tv's with no other splitters in the coax lines. And the same with a 3 way splitter , the outputs of the 3 way splitter go directly to the 3 Tv's with no other splitters in the coax lines. There will be no splitters connected between coax the comes from the antenna and the input of , 2 way splitter , 3 way splitter , or 4 way splitter.
