Tv Antennas and Reception
This is not trick information. If your imagination takes over about all of the , ands , buts , maybees , you will come to a dead end. The information about trees is not trick information. What I am saying is , IF <-- notice the word IF. If there are trees to the south , and IF the trees are close and IF the trees are BIG and THICK and DENCE then some of the Tv transmissions can be reduced in strength. When you are standing on the roof of the house , and you can see across the tops of trees to the horizon then the reception should be fine.
