Tv Antennas and Reception
The typical tripod antenna mount is 3 feet high. A mast ( the pipe that the antenna is mounted on ) is a few feet long , so with the mast in the tripod mount and the antenna attached to the mast then the antenna will be about 5 feet above the roof. No guy wires will be used. Tripod mounts are very Sturdy and Strong. Chimney mounts are very Sturdy and Strong. Peak of the roof eave/gable mounts are very Sturdy and Strong.
