Tv Antennas and Reception
A rotor Will Not be used. A rotor Will Not be installed. You Will Not buy a rotor. You Will Not have a rotor in your hands. You Will Not be looking at a rotor. You Will Not mount a rotor on the mast. You Will Not mount the Tv antenna on the rotor , because there will be NO rotor. When Tv antennas are installed the Tv antenna is turned by hand to the left and right to find the strongest reception. Turn the Tv antenna a few degrees to the left and a few degrees to the right to find the strongest reception in the direction of the Tv stations you will like to receive.
