Old 10-Jun-2011, 2:23 AM   #7
gossamer
Originally Posted by John Candle View Post
The Tv transmissions are very strong and you will receive way too many channels to watch. I suggest a Winegard HD7082P all channel antenna aimed at about 190 degree magnetic compass to start with , turn the antenna to the left and right for strongest reception of the Tv stations at 169 magnetic compass and 214 magnetic compass.
Do you mean try these different angles to experiment which is best? Later you mention that a rotor won't be needed, so it was a little unclear to me.
An antenna amplifier Will Not be needed.
Am I to infer that I'm so close that the signal will be strong enough as it is? It's probably obvious, but just curious if there was another explanation.
I suggest mounting the antenna on the roof with a , tripod mount or chimney mount or peak of the roof eave/gable mount.
So a tripod would only be a few feet high, correct? It wouldn't require guy wires or anything else more involved to affix it to the roof?
Any trees we do have in the way would probably not be a significant obstruction, if at all, so you believe the roof-level height would be sufficient?
Thanks so much. Really appreciate your time.
Best,
Dave
gossamer is offline   Reply With Quote
