Old 9-Jun-2011, 10:14 PM   #3
gossamer
A roof mounted all channel antenna aimed between 165° and 170° (compass) will provide an extensive line-up, better than almost any other around the country.
Yeah, I used to be able to see the twin towers on my way to work.
Consider antennas such as the Antennacraft CS290, Winegard HD7015 and Channel Master CM-3016. You should not need an amplifier or rotator. If you go with a larger antenna you may add additional low power signals to your line-up.
It looks like the Winegard (31 elements) is better than the Channelmaster (24 elements), but the Channelmaster is more expensive. Am I using a reasonable metric to make a purchasing decision?
The Channelmaster is under $50 from Amazon, including shipping, and they have an incredible return policy.
Is the Channelmaster a safe purchase?
Thanks again,
Dave
gossamer is offline   Reply With Quote
