A roof mounted all channel antenna aimed between 165° and 170° (compass) will provide an extensive line-up, better than almost any other around the country.
Consider antennas such as the Antennacraft CS290, Winegard HD7015 and Channel Master CM-3016. You should not need an amplifier or rotator. If you go with a larger antenna you may add additional low power signals to your line-up.
