Old 9-Jun-2011, 7:44 AM   #4
overdrunk
Thank you both, sir.
The Tvfool shows some 2edge channels with reasonably high NM, e.g., KTSF 14-18db. I previously used a RCA751 antenna which could not bring in this channel. So I replaced it with 91xg, the highly recommended antenna, but still could not receive the signal from this channel. By the way, I had a RCA preamplifier installed with the antenna. So why is this? I suppose to bring in this channel even with 0 db gain antenna. But no matter how much I tried, I had no return for this channel.
overdrunk is offline   Reply With Quote
