The antennas YA1713 pointed at WNNY and HD9095P pointed at Utica and the 2 antennas connected with a UVSJ and the output of the UVSJ connected to a AP8700 preamp can be mounted at 20 feet or so high , there is no increase of signal strength by going higher. The Syracuse stations signal strengths are in the negative NM(dB) numbers and have co channel interference , I do not believe that reliable reception will happen. The Utica stations are likley to have the same programing as the Syracuse stations.
