If you will like to install a outdoor roof top Tv antenna then I suggest the Winegard HD7000R. And keep the variable attenuator handy to dial down those strong signals. If you use a outdoor antenna , ground the coax with a coax grounding block. The place to ground to is the house ground rod. The next best place to ground to is a cold water pipe , it must be real metal pipe not plastic. Grounding the shied of the coax directs unwanted signals to ground. Homedepot and Lowes have all manner of grounding supplies.
