Old 8-Jun-2011, 7:37 PM   #6
wperry1
Originally Posted by John Candle View Post
The television transmissions are VERY STRONG Do Not use any type or kind of amplifier. Here are indoor antennas to use , http://forum.tvfool.com/showthread.php?t=233. Point the Tv antenna at about 40 degree magnetic compass. Here is how to aim Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html The transmissions are so strong that I recommend variable attenuator , Antennas Direct , model number 1296F , to Dial Down the signal strength and the multipath signal strength.
Thank you. I have a local electronics shop where I can pick up attenuators so I'll try that first and look to order a directional antenna if that doesn't do the trick.
wperry1 is offline   Reply With Quote
