Old 8-Jun-2011, 3:18 PM   #21
Originally Posted by bambam0099 View Post
So am I correct in assuming that this one antenna pointed 180 degree mc will get the Utica and Syracuse channels? (minus ION as you said)
If you aim a 91XG at 180° you may get only 3 networks, all from Utica.
Go back and study my post on June 6. If you change ANYTHING, the suggestion is invalid.
To get Syracuse the 91XG must be aimed at Syracuse. Even then some of the Syracuse stations may be marginal. The use of a AP 8700 preamp instead of a 7777 could loose the weakest Syracuse stations, especially if you add a splitter to the system.
To get Utica the 91XG is not the optimum antenna. WKTV is 22° off axis from the other Utica stations. The 91XG is extremely directional and only necessary if you want to receive Syracuse.
If you want a single antenna solution for Syracuse and Utica you MUST have a rotator.
