Your original TVFR indicates you should have more than enough signal with no amplifiers. So let's start with the basics, can you test with just the HBU-33 and one good coax... first with the HBU-33 in it's present location and second with the HBU-33 outside in the clear.
Of course this would be using only one set with the most helpful signal strength/quality metering.
The goal is to determine if the garage location is a workable location for the antenna.
