Old 22-Mar-2010, 4:14 PM   #6
bjlIV
Originally Posted by kb2fzq View Post
Being that you want to remain with the current antenna, the only thing you can try is to go up, get the antenna as high as possible without a potentential for a wind storm to knock it down. It may help, it may not. Other then that, a directional antenna is the only other answer.
I will try to raise the antenna, i can probably go up a few feet(2-3) with the current mounting solution.
Originally Posted by Dave Loudin View Post
A couple of suggestions:
1) The MS2000 is not perfectly omnidirectional. Have you tried rotating it to see if anything changes?
2) Due to scattering/reflections/blockage of nearby objects, hot spots turn up where you don't expect. I'd bet that's the case with your friend. Moving your antenna might help in a similar way.
If I were starting fresh, I'd find a bow-tie array without a reflecting screen, since your stations are in two groups roughly 180 degrees from each other. There's a home-brew solution that works well with high-VHF/UHF (NOT the design you find in youtube videos.)
1) wow, i wasn't aware that omnidirectional wasn't perfect...I have not tried this at all...that will be my first attempt.
2)It's a chimney mount, so i only have 4 places I can try to mount it(each corner), but I will give this a shot also.
second...noone is concerned about the cable reuse? I hope not, just wanting to make sure!
thanx guys! I knew i could get some helpful advice here.
bjlIV is offline   Reply With Quote
