Old 7-Jun-2011, 12:49 PM   #10
Originally Posted by bambam0099 View Post
how would I install a 91XG and DB-4 on the same mast and would I connect both to the preamp?
I had a response "offline" that said "the stacker" would get me the Utica and Syracuse channels. I found that antenna...is that a viable option also?
The stacker is a combination VHF/UHF antenna. The Utica and Syracuse stations are all UHF. The one VHF station worth receiving is aimed in a different direction. The stacker aims both antennas in the same direction. The gain of the stacker is probably too low for the Syracuse stations. Those factors suggest that a stacker would disappoint you.
The cheapest way to go between Syracuse and Utica is an A/B switch. There is no cheap and efficient way to combine them. You can combine a VHF antenna for WWNY with the Utica antenna, and get a full compliment of networks without a switch.
