Old 6-Jun-2011, 9:35 PM   #4
wperry1
Originally Posted by John Candle View Post
Is this a , warehouse , a shop , house , condo , high rise , apt. , basement , mobile home , motor home , etc.?? If above ground - how many floors?? Is the building wrapped with any type or kind of metal such as but not limited to metal siding?? Are the walls made of poured concrete?? Is there brick from ground to roof?? Does the building have a metal roof??
Sorry I left that out. I am in a 2 story house with lower story being half under gound. The TV and antenna are on the second floor so the antenna behind the TV is about 15' off the ground. The TV is at the NW corner of the house with the back facing N so there is clear shot (except the wall) to the towers. The walls from inside to outside are Drywall , 2x4 and thin insulation, Plywood, Wood siding. The rest of the house is wood construction, no metal aside from nails, pipes, and wires. (there are no pipes in the wall in question).
Also, per your reference to the issue with virtual vs real channels, I have updated my original post with the real channels for the stations I am concerned with.
Thank you for your reply and please let me know if you need any more info.
wperry1 is offline   Reply With Quote
