Old 6-Jun-2011, 7:55 PM   #7
bambam0099
Originally Posted by John Candle View Post
Your receivable Tv stations are weak in signal strength and are in different directions. Here is one way to do it. . To receive the stations in different directions down to WSPX ION Tv , you will need a high gain directional antenna. To do it with one antenna you will need a Winegard HD7698P antenna and a Winegard AP8700 preamp mounted on a ChannelMaster CM9521A rotor. The antenna will be 20 to 25 feet high. Of your reception situation going higher with the antenna does not get a stronger signal. The up side of one antenna and rotor is the stations can be received with one antenna. The down side is , the person that has control of the remote control of the rotor is the one that controls where the antenna is pointed. I'll be back with a easy to understand explaination of doing it with more then one antenna.
Thanks, I feel like I'm actually learning something here!
Very interested in your explanation of using/joining more than one antenna for a single "source" and then splitting to possibly 3 tv's since using a rotor would be chaos in our house, especially when my wife and I are fighting over what channel to watch! LOL!
Eagerly anticipating your explanation.
Thanks again...really appreciate it!
bambam0099 is offline   Reply With Quote
