Tv Antennas and Reception
Your receivable Tv stations are weak in signal strength and are in different directions. Here is one way to do it. . To receive the stations in different directions down to WSPX ION Tv , you will need a high gain directional antenna. To do it with one antenna you will need a Winegard HD7698P antenna and a Winegard AP8700 preamp mounted on a ChannelMaster CM9521A rotor. The antenna will be 20 to 25 feet high. Of your reception situation going higher with the antenna does not get a stronger signal. The up side of one antenna and rotor is the stations can be received with one antenna. The down side is , the person that has control of the remote control of the rotor is the one that controls where the antenna is pointed. A way to to do it that each person has control of where the antenna is pointed is to have a , antenna , a preamp and rotor for each Tv.
