Old 6-Jun-2011, 7:16 PM   #1
wperry1
Multi-path Issue/Intermittent Reception Problem
Hi everyone,
I am new here but wasn't able to find any threads that seem to address my issue.
I live just outside Portland, OR and have LOS to my local towers at ~4 mi.
Here is a link to my Signal Analysis results
Current Setup ~15': http://www.tvfool.com/?option=com_wr...2193e1300b87a9
Attic/Roof Option ~25': http://www.tvfool.com/?option=com_wr...21930ab63b50f5
I am currently using a simple dipole from speaker wire (i know, i know, I'm cheap) in to my TivoHD. 90% of the time I get 90%+ signal on all the stations I care about (43, 40, 8, 10, 12, 22, 33, 30) but the other 10% never seems to happen when I am watching live TV so I can't see what the signal looks like at that point. Our top channels are 43, 40, 8, and 21 and they have all had the problem as some point. Adjusting the antenna seems to move the problem from channel to channel.
So, now that I have detailed my problem, my question is, does this sound like multi-path distortion, other interference, or something else entirely? What are my options for the most likely cause of the problem.
PS: About an hour ago, I threw together a single bow-tie antenna with no reflector which is now using shielded RG6 to get to the TV ( <6ft cable ). I am seeing slightly higher signals than with the old antenna 95%+ but I have no idea what to expect when it starts recording later.
Thanks in advanced for any help. From the posts I have read so far you guys have a good group here!
PPS: I just found a more detailed signal information screen on my Tivo which shows the Signal Strength in the high 90s and SNR between 29 and 32 for to channels mentioned above.
wperry1 is offline   Reply With Quote
