Old 6-Jun-2011, 5:25 PM   #5
bambam0099
It makes sense to me. The Syracuse stations on analog VHF would have made it to Remsen. To get them on UHF digital is possible but difficult.
If you want as many stations as possible it's worth trying for Syracuse. The antenna height doesn't make enough difference to install a tower. I'd get a 91XG, aim it at Syracuse, connect it to a 7777 preamp, and see what you get.
To get Utica stations may require a rotator or a second UHF only antenna such as a DB-2 or DB-4. WWNY is also possible with a Y10-7-13 connected to the VHF input of the 7777 preamp. There's no need to turn the VHF antenna.
Really, really appreciate the response and the suggestions.
You mentioned 3 separate antennas. WWNY is not worth the cost of another antenna to me so, my final question would be, how would I install a 91XG and DB-4 on the same mast and would I connect both to the preamp?
I had a response "offline" that said "the stacker" would get me the Utica and Syracuse channels. I found that antenna...is that a viable option also?
Man, I thought this was going to be easy! You guys are worlds above me in this stuff!
Thanks again
bambam0099 is offline   Reply With Quote
