Tv Antennas and Reception
RG-6 coax is the coax to use. . Drill the holes size so the connector on the end of the coax will go through the hole. The number one mistake that people make when drilling holes is making the holes too small. . Drill the hole through one side of a wall , ceiling , floor. Remove the drill bit from the wall , ceiling , floor , and with a flash light look inside and see if any thing is in the the path of continued drilling like , wiring or pipes. Can all so use a wire coat hanger to feel around with. Why would you put a Tv above a fire place?? You will get a crick in your neck from looking up all the time if it's in the living room.
