Old 5-Jun-2011, 11:27 PM   #4
John Candle
Tv Antennas and Reception
The Digital broadcast television transmissions are strong at your location. One of these indoor antennas at each Tv will work fine , http://forum.tvfool.com/showthread.php?t=233 . Provided that the building is not wrapped with metal siding or a metal roof or poured concrete walls or brick from ground to roof. Here is how to point indoor Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html , point the indoor Tv antenna at about 20 degree magnetic compass. . Or a Winegard Hd7694P antenna can be mounted in the attic and pointed at about 20 degree magnetic compass , the HD7694P will supply plenty of signal to 2 Tv's. Provided that the roof or walls are not made of metal. Here are some places to buy Tv antennas and etc.. , http://www.solidsignal.com , http://3starinc.com , http://www.starkelectronic.com , http://www.amazon.com
