Old 5-Jun-2011, 3:08 PM   #15
GrahamA
Dear Tower Guy and John Candle,
"Have you switched the TV from the CATV mode to off air mode? "
(I am not even gettting a signal when I am not using the amplified splitter and only using 3 feet of cable. No signal at all. I can't figure it out. I have also tried not using the pre-amplifier either. Still no signal.)
Yes, we switched off CATV mode and to OTA mode using the antenna. We have TVs with and without internal tuners. For TVs that are monitors (without tuners), I am using an Electronic Master Digital ATSC HDTV TV Tuner p/n DCT102 purchased from www.barrel-of-monkeys.com.
There are no problems with the connections on the coax. We have checked those connections. I hope there are no internal problems with the coax as that would take a major effort to solve at this point. I do not have coax testing equipment either, but I suppose I would have to get it if I rule out everything else after getting a Winegard antenna and trying that.
GrahamA is offline   Reply With Quote
