Old 5-Jun-2011, 3:14 AM   #16
Amplifiers can increase signal strength but will not correct other impairments. That said, the PCT 8 Port DA handles fairly high input levels.
If you don't see an increase in signal quality, you will need to continue searching for a better antenna location or a higher gain antenna.
...ran some RG6 (not quad shield, not sure how much diff that would make).
You're fine, locally generated IF from a satellite LNB needs the extra shielding, OTA signals do not.
