Old 3-Jun-2011, 2:12 PM   #7
Tower Guy
Originally Posted by steakman1971 View Post
Channel Master 2016 that is supposed to get VHF/UHF. I hooked it up - still not getting Channel 12. .
The 2016 is about the smallest VHF antenna available. Your location is behind two hills and the antenna is in the attic. That's a combination destined to fail.
The UVSJ will help slightly, but the Y10-7-13 is the right solution for you. It may not work in the attic, but try it there first. An alternative to the UVSJ that will also compensate somewhat for the attic location is a AP-2870 preamp. That amplifier has two inputs, one for VHF and one for UHF.
