The 2016 on the roof may be enough antenna... try it. In the attic, well... I have doubts.
If you must keep the antennas in the attic, The Winegard YA-1713 or Antennacraft Y10713 will give you a fighting chance. Use a UVSJ to combine the CS-4 UHF with the VHF antenna.
If you had asked before buying anything, I would have recommended a roof mounted Winegard HD7694P or larger. Or alternately an Antennacraft HBU-33 or larger.
Do you have more than one TV to connect?
