Old 3-Jun-2011, 2:50 AM   #1
steakman1971
No VHF in Northern KY
Hello - I recently dumped cable and installed a Direct ClearStream 4 antenna in my attic. It does a good job of getting the UHF channels in my area - getting about 80-90% signal strength according to my TV's setup tool.
VHF (Channel 12, CBS in Cincinnati) is another story - i'm not getting anything.
After doing some reading (after buying - not the best way to find stuff out!) - I guess the ClearStream4 is just a UHF antenna?
I bought another antenna - Channel Master 2016 that is supposed to get VHF/UHF. I hooked it up - still not getting Channel 12. I've not spent a lot of time aiming the antenna yet - it's generally pointed in the correct direction. Gets about 50-60% signal strength on UHF. Not getting anything on VHF.
My tvfool report looks like:
http://www.tvfool.com/?option=com_wr...21934125498438
Few questions:
Suggestions on what to do about VHF? I'm going to play with the Channel Master some more when I get time.
Can I use a combiner/splitter to "combine" the ClearStream4 and the Channel Master signal together (assuming I get VHF on the Channel Master)?
I also bought a preamp - but its not hooked up yet.
Are there any good guides/books on this? I feel lost reading about the preamps, gains, etc. I also realize that installing the antenna on my roof would be much better - might consider this at some point (if I can convince the wife... )
Thanks in advance for any tips.
steakman1971 is offline   Reply With Quote
