Old 2-Jun-2011, 1:49 AM   #2
John Candle
TV Antennas and Reception
An indoor antenna will not work in the basement. I recommend a Winegard HD 7694P antenna mounted on the roof. Do Not connect a active cable coax to the antenna system coax at the same time. Point the Tv antenna at about 230 degree magnetic compass. Here is how to point Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html . This will get you the stations to the , west , south west.
