Old 1-Jun-2011, 9:59 PM   #16
jc5000
GUM, This picture you embedded looks exactly like the setup I have. I guess this pre-amp is also the transformer because coax cable goes into the black box from the house but the two-wire cable comes out of the box to the antenna connections. Then there is another powered box inside the house that receives the coax from the black box. It is distributed from there to the TVs thru additional coax cable.
That sounds like the actual amplifier. - Example -The indoor power supply and power insertion block is often mistaken for the amplifier. You may find that once ALL the amplifier components are removed your reception may dramatically improve... here's hoping anyway...
There are some older matching transformers that could look like that though.
jc5000 is offline   Reply With Quote
