If you use the Winegard preamplifier that I mentioned: the HDP-269, the extra cabling will not be a problem, as the preamp will compensate for the extra line losses. For best results, though, the splitter should be in the line AFTER the preamplifier power supply, as most splitters won't pass the DC power from the power injector. That may require a little additional wiring to make it all work.
