This Manual illustrates the location of, and how to connect the matching transformer. Notice the illustration at the end of step 3. If you find that you can not loosen the hardware to disconnect the matching transformer wires from the lead in terminals (illustrated at the end of step 1), you should consider replacing the antenna.
If water has entered the coax cable, it needs to be replaced.
