Old 31-May-2011, 9:56 PM   #1
jc5000
Reception Problems
I'd like some advice about potential solutions to weak or intermittent TV reception. I have a standard multi-band rooftop antenna (about 10 years old) pointed south to southeast, supposedly the direction of most of the broadcasters in the area. I have messed with the direction somewhat with no signal improvement. The antenna is connected to some kind of amp that is then split into cables going throughout the house to two TVs and an empty jack.
According to the chart below, i should have great reception. I never had a complaint about the analog signal but have experienced intermittent lost signals and pixelation in the digital era. The typical signal at the TVs are 25 to 32 db with the amp and 22 or less (no signal) without the amp. I was thinking of trying a new antenna but am not convinced this would help. However, I am open to suggestions before i call the cable company.
http://www.tvfool.com/?option=com_wr...21930b794fcc85
jc5000 is offline   Reply With Quote
