Old 21-Mar-2010, 8:13 AM   #3
WoBe
Help with reception-thank you!
Tigerbangs-thank you so much for your help. We never would have figured this out on our own. Do you think it would be OK then to go back to having the antenna hooked up to the structured wiring box I meantioned in my orig post, which is located about 50 feet from the antenna and the TV? I read where long runs of cable can weaken the signal. However, with the antenna setup that you are recommending, maybe this wouldn't be an issue? Thank you.
WoBe is offline   Reply With Quote
