Old 21-Mar-2010, 4:04 AM   #1
fritzel67
Just Moved and Need an Antenna Recommendation
I recently asked for some help while living in Spring Hill, TN and have since moved about 18 miles north closer to Nashville.
We are now in a two-story townhouse where my only option is to locate the antenna in our attic. I currently have a Terk HDTVo. It pulled in 14-16 channels at our old place on a 15 ft pole outside. So far I have tested with this same antenna indoors (on top of some boxes next to our TV) and amazingly it detected 14 channels of which 7-8 are watchable. However I've noticed I seem to need to move the antenna a bit when switching for instance between channels 8 and 28 (PBS and ION).
Anyway, any recommendations for something that would work in my attic would be great. Unless I can get by with a multi-directional it appears I may need a rotator setup.
Here is a link to my signal analysis:
http://www.tvfool.com/?option=com_wr...b7c84378bc994b
Thanks in advance.
Tracy
Last edited by fritzel67; 21-Mar-2010 at 4:04 AM. Reason: Updated with Signal Analysis Link
fritzel67 is offline   Reply With Quote
