TV Antennas and Reception
The reception of Tv stations at your location is weak. A variable attenuator will make the stations even weaker. To attenuate means to reduce the strength. You are chasing your tail. I suggest that you STOP. I suggest that you post back here with the antenna heights at 50 feet and 100 feet. . I can help you better if you will private message me with the exact location of longitude and latitude.
