Old 29-May-2011, 6:16 PM   #5
Tower Guy
Originally Posted by delsol View Post
The Wineguard 7696p looks good what do you think of the xg91
Thanks
The 91 XG is a fine UHF only antenna that is not right for you. KOLN and KUON are on VHF frequencies.
If you want to pick up the LPTV stations at 340 degrees you could use a smaller cheaper DB-2 UHF only antenna. I did not investigate if all the networks have LPTV stations in that direction.
