Old 28-May-2011, 1:50 AM   #12
Originally Posted by RichCNY View Post
I actually do have that model, but the only downside to that setup is if the htpc is using tuner1 with local then tuner2 is the only available with whatever syracuse stations I can get if someone else wants to watch something different on the htpc or a seperate pc. I may end up doing that but it wasn't my "ideal" outcome. Thanks for the tip though!
My solution has been to 'pool' several HDHRs and do recordings on an XP box using batch-files and the scheduling utility built into XP. This leaves me the freedom to select the specific tuner (antenna) and have at least one tuner free for live viewing. My previous link has examples of the batch file I use.
