Old 27-May-2011, 11:31 AM   #8
RichCNY
John,
Sorry for stating the mileage factor again, I realize there is more to it but its just the first thing that comes to mind. In regards to distribution the signal will travel about 30 ft from the roof (once moved), into a two way splitter which feeds an HDHomeRun network TV tuner (within a foot of the splitter). I can envision somewhere down the line a need to split it possibly 4 ways and maybe distribute via coax to some parts of the house, but for now its only split twice and the coax's job ends when it hits the HDHomeRun.
For a test I have removed the splitter and hooked the coax directly to the tuner (with the antenna still in the attic) and I can get approximately 30% Signal Strength on 47. With the splitter it only drops slightly at this point. If it doesn't rain all weekend I will attempt to move the CS2 on the roof and see what I get from there and I will also check out the Radioshacks in the area to see what they have in stock.
RichCNY is offline   Reply With Quote
