Old 27-May-2011, 7:01 AM   #6
John Candle
TV Antennas and Reception
Reception strength at the receive location is more important then mileage. How many splits will take place is more important mileage. Will you have , 1 connection , 2 connections , 3 connections , 4 connections , on the antenna coax? . What you will like to receive is more important then mileage. At your location , reception down to WTVH-DT CBS 47 is doable with the antenna connected to one connection point , like to the HTPC or one Tv. Beyond that , I recommend a distribution amplifier , to know the distribution amplifier to use we need to know how many connection points there will be. Also my suggestion is the antenna needs to be on the roof. Not in the attic. WTVH is weak and the antenna will need to be on the roof. Radio Shack sells AntennaCraft antennas.
