Old 26-May-2011, 9:00 PM   #11
John Candle
TV Antennas and Reception
Also check ALL connections. Look inside the coax connectors on the ends of the coax and see if the metal foil shield or metal shield are pushed in toward the center metal wire , look for metal flakes on the foam that is between the center wire and the outer metal foil shield and shield wires. ALL So check ALL connections. ALL So check ALL connections. How many Tv's are connected?? And how many Tv's are connected??
