Old 19-Mar-2010, 7:17 PM   #1
bjlIV
Question Help with Reception problem - existing setup
Ok,
Here is my situation. My TVFool Link is here. I have a Winegard MS2000 chimney mounted, about 20ft off the ground. It is about 4-5 ft higher than the peek of my roof. I am using the stock power amp that came with it. I have not split the signal anywhere along the chain, just one tv(i would like to split later however). I have a friend with the same setup, except she is about 3/4 mile from me, and lower in the valley(i am near/at top). From TVFool, I should be receiving (Green, Yellow, and POSSIBLY some in red)
I just shut off DishNetwork at my house. I used the Coax from that Sat dish(since it was already run into the house) for my MS2000. I think this should be fine, but wanted to mention it in case it could be part of my problem? The total length is somewhere between 40-50ft, I would guess closer to 40. It is a dual coax cable with a ground wire also. I ground the wire on the mast, and found the live coax that was running into my house. The other piece looks to be terminated outside before it comes inside. I am not sure the reasoning of why they ran two wires?
well, I am not receiving some of the digital channels in both the green and yellow. The CBS station (5.1) in yellow is the main channel I desire to pickup that I am currently NOT picking up. I would also like to get the Fox station(24.1) in red, but am not too worried about that if it doesn't happen.
The troubling part of this is, my friend picks up CBS(5.1) perfectly, with hers mounted in her attic, and at a (should be) worse location. However, she only gets 1-2 analog channels, were as I get about 5-6. The first 5 channels listed in green, I do not get for some reason? Am i too close to the source? To much power? Not a big concern really, just more of a question. The NBC(51.1) channel i get, but it flickers/jumps sometimes, its not the great signal the other two digitals' are(13.1 and 29.1) I am also NOT picking up 20.1 or 57.1 either?
again, 5.1 is my main concern, but i would like to pick up, if possible, 24.1(long range Fox), 20.1, and 57.1.
I will answer any questions you may have that I didn't provide, but I hope to have given enough info for some good suggestions on what I may could do differently.
Thank you!
bjlIV is offline   Reply With Quote
