Old 25-May-2011, 10:45 PM   #35
sdubb
Originally Posted by No static at all View Post
How much elevation tweaking did you do? That has been the key for getting difficult channels in many situations for me. Just a few inches can make or break reception on UHF. I suggest raising/lowering the antenna in 3-4 inch increments. Re-test all channels each time as the tweaking may require a compromise to recieve everything.
How far is the antenna from the roof or any other metal objects?
I did a little bit of tweaking as far as height is concerned. I started with the antenna at the back of the house on a pole about 12-13 feet. Then I decided that I needed to move it to the front of the house. Nothing really changed. I decided to mount a J-mount on top of a false wall on the roof which gave me about 8 more feet. So now my VHF/UHF antenna sits at about 21' in the air.
Like I stated the antenna is on the roof at about 8' above the actual roof. I dont see any metal objects any where close by, not even any power lines.
I can provide pics if you guys think that will help.
sdubb is offline   Reply With Quote
