Old 25-May-2011, 10:38 PM   #34
sdubb
As far as preamps go, the power is fed up the coax from inside the building. The amplifier should be located within a short coax jumper length of the antenna. It would be quite unusual to locate the power supply on the roof or outdoors, most are not rated for such installation.
This might be the killer... There is only one line that enters the house, If I have to add a seperate line its going to be a very interesting run to get the cable where it need to go (same place as the other one) they have all been run thru the house.
sdubb is offline   Reply With Quote
